I have a KUDE60FVSS1 dishwasher which was giving error code 6-1. It would wash but sometimes not complete the cycle, leaving wet dishes and sometimes water in the tub. After reading repair stories I decided to replace the Pump and Motor Assembly.
Part WPW10056309 was delivered very quickly! Thanks AppliancePartsPros!
However, after install I still get the same code. In addition, the dishwasher will not start at all. The start button just blinks several times after pressing. This did not happen previous to the repair.
Not sure what to do now. Tried running diagnostics using the 123123123 method, but that would not start either. Double checked all my connections to the new part and they are all fine.
Thinking of returning the part and getting a new dishwasher...
Jon
