Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
My Kenmore 600 series washer, model # 11026132413, just buzzes when I press start. The lid locks and that's as far as the cycle goes, it just buzzes until I shut it off
Before this problem started, it was working just fine except for a leak. I replaced the gearcase, which had a bad seal. When I put it all back together, this new problem surfaced.
I've checked to make sure the connectors etc, are ok and plugged in all the way. I've pulled the rotor, clutch, and stator off to visually check, and they look fine. As I said it was working before I replaced the gear case.
With the rotor off I can grab the slider and spin the tub by hand, so its not stuck
Any help is much appreciated
Rank: Guest
When you order the suspension rods online do they give you send you four or do they send you only one it doesn't specify on the website
