gesingle
#1 Posted : Wednesday, March 29, 2023 2:18:18 PM(UTC)
gesingle
Does anyone know where I can download a schematic of this dryer? SearsPartsDirect does not show a schematic. My specific problem is the four red wires coming from the dryer thermistor and high limit thermostat that go to the P4 connector on the Whirlpool W10606685 control board. Somehow all four of those wires got pinched and broken. I can splice them back together, but since they are all the same color, I can't tell which wires match. A W10606685 schematic or connector pinout description would also give me the needed clues. Wires go to pins 1,2,3 and 6 on P4.
gesingle
#2 Posted : Thursday, March 30, 2023 2:51:33 PM(UTC)
gesingle
Solved. I found a service manual with wiring diagram. Inlet thermistor (heater box) goes to P4-1,2. Outlet Thermistor (blower) to P4-3,6. Outlet thermistor should have red/white wires, but the factory must have run out of that wire!
