Hello My wife started our dishwasher today and noticed shortly after it quit. No power to the door top button panel. I came home, confirmed we have power to dishwasher, tested continuity on noise filter assembly fuse it was good. Pulled door apart and I have a burnt wire going onto main board. It’s 1 of 2 larger plugs that plug onto the board. Each plug has two wires. The plastic plugs are blue and black. The burnt wire is the brown wire in the blue plastic plug (other wire is blue). My question is do I replace the board? Or need to figure out why the wire burnt? I’m thinking pump was drawing too much juice. Main board fuse is also ok. I’m trying to add a photo as I know this would be 100% better with a photo. Hopefully this link works. It’s the blue square plastic plug bottom left of this photo. Any help is greatly appreciated Thank you! https://images.app.goo.gl/Sj9iPYBVGBMojpjP7BoardEdited by user Tuesday, March 28, 2023 9:32:55 PM(UTC)
| Reason: Can’t get photo to attach
