Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Greetings! I am currently having issues with my Kenmore Elite 5 washer and can't find any answers online.
It started out with an F30 code which is the soap dispenser. Washer would not run the load at all and I just ended up with wet clothes. I replaced the motor for the dispenser, and it seemed to work a little better, but still will not run a load and I still get an F30 code.
I am also getting an F35 and SUDS errors. I tried checking the tubes and filters for any blockages, the washer seems to drain fine.
I am at a loss for what to do and I'm out of clean clothes! Any assistance would be most appreciated.
- Isaac
