pashwin
#1 Posted : Sunday, February 19, 2023 9:20:03 AM(UTC)
pashwin
United States
Hello - My dishwasher is not drying dishes. I check the continuity on the heating coil and it is reading 12.9. I checked the thermostat as well and it is at 0.1 so there is continuity. I am lost as to why it not drying the dishes. I checked the harness as well and it appears to be ok. The dishwasher does go into the drying cycle (based on lights I see on panel) . To test , I even opens the door 10 minutes into the drying cycle but no steam or it was not as hot as it’s supposed to be . The coil at the bottom was also not hot to the touch. Any help is appreciated. Should I check the turbidity sensor / replace it?
ThatGuy
#2 Posted : Sunday, February 19, 2023 10:26:02 PM(UTC)
ThatGuy
Groups: Expert
United States
The question... is there voltage to the heating element? If not, what is stopping it? Thermostat, broken or damaged wire, or the computer that controls it?
