Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
The broiler element broke on my LG LSE4611 oven, I replaced it. I then turned the broiler on but it does not heat up. I tested the continuity of the new element and it is fine. The broiler element appears not to have power. The cooktop and the oven (lower element) work. Any suggestions on what to look at next.
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 ![United States United States](/Content/images/flags/US.png) Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
You're model number is not complete. I used LSE4611ST/00. So this part fits that model no. I suspect your broil relay was damaged when the element burned out. Or it could be bad wire or connector.
Range Oven Relay Control Board EBR80595407
Rank: Guest
Do you know how or if there is a way to test the relay controller? Edited by user Wednesday, February 8, 2023 4:08:30 PM(UTC)
| Reason: Missing word
Rank: Guest
.. Edited by user Wednesday, February 8, 2023 4:10:38 PM(UTC)
| Reason: Deleted - duplicate post
