Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Whirlpool wfe530c0eb0 range, several years old. Started cooking using both oven and cooktop when strong smell of burnt electronics started. No elements work now, neither does the oven. When everything was turned off, display is blank, but when you turn an element on, the clock appears (but no heat). Shut of breaker and reset, but no error codes display, display is still blank. Oven does still have power, lights come on, etc. But no heating. UPDATE: Found the problem, Edited by user Tuesday, January 31, 2023 12:31:47 PM(UTC)
| Reason: Add photo
