AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Samsung dryer starts but won't turn drum or heat
I've got a Samsung DV45K6500EV/A3 dryer. Turns on fine, no error codes. When I select start, it seems like it's starting but drum won't turn over nor will it heat. I checked the drum belt and it seemed to be fine.
How to tell if thermal fuse, thermistor, or else?
I'd rather not take it completely apart and check continuity on each one if I can help.
Ideas?
Dryer Repair
