AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer won't start after changing fuses and timer
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have a Maytag MDE6400AYW Serial #12499940AT.
I have changed both fuses, and the door switch, and the timer. I don't think I can spend more money to fix it!! I need to find out what is wrong. The dryer starts once in a while with a hard prayer and fingers crossed! But I can't just turn it on like I did before. It still heats up properly. I have checked the vents and blower for any blockage and nothing is there. To tell you the truth, the dryer is pretty clean.
The light still works and shuts off when the switch is pressed. There is light squeaking from one of the wheels.
I don't know what could be the problem.
Liv
Dryer Repair
