Joined: 12/18/2022(UTC) Posts: 0  Location: Minnesota
in order to remove the user interface panel, there is a light gray plastic cover which obscures the tabs on the user interface panel. it is held in with two screws and then "magic"? There is a rectangular hole which one would believe is there to access a tab. however, I have not found a way to "release" this part. Not really interested in breaking it either. Have not found any info on the WWW, that shows what to do in this case. Ideas? [img=https://1drv.ms/u/s!Aqe59t6xfq6BgrYXxER0S2RNxOlvwA?e=6zBpu3]mft2776fez00 plastic cover under UI panel[/img]
