jazmanfire
#1 Posted : Thursday, December 15, 2022 3:19:13 PM(UTC)
jazmanfire
United States
I own a GE Harmony washer: WPGT9350C0PL. It is exhibiting a strange issue. The first load of laundry of the day, it works without issue. So far the issue only occurs on any load after the first load. In the middle of the cycle, it simply stops and shuts off. The display goes dark. It is as if someone unplugs the unit. I happened to be there to witness it. It was after the spin cycle. The unit was letting in water for the rinse cycle, and it simply stopped and the display went dark. It will keep doing this if I attempt to recover. If I let the washer sit for about an hour, it has a chance of completing a cycle without issue. No troublecodes are present.
