AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
kenmore dishwasher 66513043K116 still not draining, after changing drain motor?
initially, the dishwasher wasn't starting, so i replaced the heating coil. After that it started working but after the cycle the dirty water remained. I changed out the drain pump (had a long voltage) and ran a cycle again and their still water left. I checked the hose for any blockage, seems fine. The filter looks fine as well. I don't have a float switch for this model I believe. Can it be the Turbidity Sensor or should i just call a tech at this point?
Dishwasher Repair
