Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
The door of our new Miele dishwasher G5266 SCVi snaps shut making it difficult to load. Any ideas on how to fix it?
To open a dishwasher door stuck closed, first make sure there is no lock keeping the door closed. Some dishwashers have a child lock or control lock, which will prevent the door from opening. If a lock isn't the cause, you will need to manually open the door using a pair of vice grip pliers and an Allen wrench. Slide the Allen wrench along the top and use it to locate and lift the door's latch. If it seems difficult to you I recomment you better hire professional dishwasher technician
