dishwasher wont start the top green light on the dry heat is flashing nothing else works. have tried holding the button to see if it would unlock or lock and nothing happened. tried to reset by holding normal and dry heat, then both lights on normal and dry heat flashed waited about ten minutes and no change. then turned off breaker and back on, then the top green light on dry heat was back to flashing. any help would be greatly appreciated Mark
