Guest
#1 Posted : Sunday, November 13, 2022 8:12:45 AM(UTC)
Guest
Rank: Guest
United States
I have a SxS GE fridge (Model GSS25JFMAWW) that needs a replacement freezer gasket. The OEM part number is GEH-WR24X10053 which, like a lot of parts for this unit is showing is NLA. Has anyone had any experience with a currently available replacement gasket that would work? I have searched for the size (15”x65”) but didn’t have any luck there either. Figured I would post on a couple of forums and see if anyone else has run in to this issue and found a workable solution. Thank you, in advance, for any guidance you can provide.
Edited by user Sunday, November 13, 2022 8:13:33 AM(UTC)  | Reason: Updated “from” field
