Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hello - hoping someone can help me with this: I have an Electrolux ESL6210LO dishwasher (PNC 911 539 079 01). It has recently developed a fault where it does not finish a cycle - it gets nearly to the end but then does not finish. It sounds like a small pump / motor is running. Its not either the wash or drain pump, but a small white device on the left hand side of the machine [unsure what it is]. Here is a photo: https://drive.google.com.../d/1I8b...ew?usp=sharingAny help appreciated on how to diagnose further or repair the issue. I'm an electrical engineer by profession, some confident with electrical safety, wiring, voltage testing etc Thanks, Matt
