Joined: 10/1/2021(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: cleveland
Water dispenser doesn’t work on my EI28BS65KS4. with the WATER red LED is ON(selected) & the dispenser is pressed I don't read 120V at the water solenoid. with the CUBES red LED is ON(selected) & the dispenser is pressed I don't read 120V at the ice line solenoid, but I DO hear the ice door opens and the auger moving. with the CRUSHED red LED is ON(selected) & the dispenser is pressed I don't read 120V at the ice line solenoid, but I DO hear the ice door opens and the auger moving. is it possible that the UI board(242041121) is not supplying the 120V voltage to the solenoids? I already replaced the main board(242115278) and it didn't make a difference for the Water dispenser issue. thanks Max Edited by user Friday, October 28, 2022 2:46:29 PM(UTC)
| Reason: Not specified
