Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
This refrigerator and freezer works fine for a few days and then stops cooling and shuts down. Unplug for a few hours and it starts up and runs a few more days. I have no ice building or frost building up on condenser, fans run, thinking it may be the inverter board. Any suggestions would be appreciated. Thanks
Joined: 11/10/2022(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: Oklahoma
Originally Posted by: Guest ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) This refrigerator and freezer works fine for a few days and then stops cooling and shuts down. Unplug for a few hours and it starts up and runs a few more days. I have no ice building or frost building up on condenser, fans run, thinking it may be the inverter board. Any suggestions would be appreciated. Thanks We have a very similar problem with our Samsung RFG298HDBP/XAA French Door refrigerator: [manf. date Jan. 2012]. We bought it used, early this year, it had apparently been in a model home. About 3 months ago the temperature settings/display, on the left door stopped functioning, just stayed on last settings, and then 3 weeks ago, the same problem as you have stated started happening. Unplugging from the wall, for a period of time, will reset the power, but the control panel will not work. Now it's down to only a few minutes of operation before shut-down. Edited by user Thursday, November 10, 2022 9:30:07 PM(UTC)
| Reason: spelling
