Joined: 10/14/2022(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: South Dakota
I purchased a used Whirlpool Thin Twin Stackable Model LTE5243DQ3 used. Finally got around to hooking it up and neither the dryer or washer will operate as they should. The only way I have gotten anything to work is to put the washer on, set the dryer to run and hit the dryer start button. I I stop either side, they both stop. Washer will fill and agitate, but not drain. Dryer heats as it should.....Yea, I thought the same thing. Had to be a government upgrade...
I am dumbfounded by this one, and the previous owner had it looked at before it sold and the tech gave it a clean bill. Does anyone have a copy of the electrical signal path so I might trace own where one of the wires is not in the right place?
Any help would be greatly appreciated.
