bpwlrp
#1 Posted : Thursday, October 13, 2022 12:27:04 PM(UTC)
bpwlrp
United States
KA KSCS25INSS00 fridge
Water flows to dispenser and ice maker if filter cartridge is NOT installed.
New filter installed get trickle of water to dispenser and ice maker. This appears to be a clogged filter but the filter is brand new.
New water valve installed but problem still exists.
How do I check if the filter housing is failing to let the input water through the filter?
Any other suggestions to correct this problem would be appreciated.
Thank you.
