Lcallen80
#1 Posted : Saturday, August 27, 2022 11:36:05 AM(UTC)
Lcallen80
United States
My check filter light keeps blinking on my dryer. I’ve tried to replace the moisture sensor but keep getting the wrong part, after being told it’s the right part. I’ve seen moisture sensor and pressure sensor and they look like the same part. Are they the same part? I’ve taken the front off my dryer completely off and cleaned the current sensors but that didn’t work. I still get the same check filter blinking.
What is the correct replacement part?? I’ve tried 6500EL3001A (which was too small )and EBD50964602 which seemed to be too big but i hadn’t take. The front off at the time. Any help would help
