When oven is turned on, error code F9 shows when temp reaches 218. Oven is turned off and back on F9 error shows again after a few degrees hotter. even when oven placed in clean mode, error shows up. Tried disconnecting/breaker but nothing. Has anyone experienced this problem and what is solution?
Rank: Guest
Groups: Guests
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Was this problem ever solved for you? Ours started doing this 3 months ago. So far the latch and the computer board have been replaced but problem has not resolved. Edited by user Saturday, September 23, 2023 1:32:23 PM(UTC)
| Reason: Not specified
