Joined: 8/19/2022(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: az
hello my lg washer is stuck on spin and will eventually give an oe code. it goes to the 1 minute mark then gets stuck. i have checked for obstructions and the replace the drain pump but still the same thing. a few weeks ago i replaced the clutch assembly and it seems like that is when this started. is there something i may have done while changing the clutch possibly? there must be some kind of senser to inform the board that the drain is not draining and getting the oe code. not sure what to do at this point. hopefully not a main board issue. any troubleshooting tips to check what may be happening would be appreciated. thanks al
