Guest
#1 Posted : Sunday, July 17, 2022 6:06:50 AM(UTC)
Guest
Rank: Guest
United States
I have a GE Profile side by side model # PSS26LGRBWW. I am trying to see why the fresh food fan in the damper won't turn off when the door is open like it used to. The fresh food fan runs all the time. The thermistors are all in range on both the fridge side and freezer. The fresh food side temp shows about 37-38 degrees, the freezer side 5 degrees. I did change out the mother board due to another issue. I don't know if the new mother board makes the fresh food fan stay on all the time or the damper section is bad. Any help would be appreciated
