Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have an LG WT7600HKA top load washer It does not turn on. I have verified that there is 120v power to the outlet. I unplugged and waited 30 seconds and re-plugged. No Start. I have followed directions that I found in a YouTube video to check the noise filter. It appears good. I replaced the Electronic Control Board. No Start. I called an appliance tech who checked and said that the Display PCB Assembly was bad and needed replaced. I replaced the Display PCB Assembly. No Start. I don't know what to do now. I when I disconnect the power cord, press the power button for 10 seconds and release, press the start button for 10 seconds and release, I hear clicks as it resets. Then when I plug in the power cord, I see a spark at the plug and I hear a loud click that sounds almost like a breaker or relay opening. This appears to be coming from the area of the noise filter. I can reset by pressing the power button for 10 seconds and the start button for 10 seconds but then if I plug in again it sparks and clicks loudly. If there is someone who can tell me what to check next, I would deeply appreciate this. Thanks in advance.
