Guest
#1 Posted : Friday, July 8, 2022 9:00:03 AM(UTC)
Guest
Rank: Guest
United States
My Bosch dishwasher model SHPM65Z56N interrupts cycles and stops with flashing red light (pointing to the floor). In order to push it forward I need to open the door and press Start / Resume button.
I've noticed that when I reset the wall switch to off to On position before starting a new washing cycle the machine completes all phases without interruptions. I changed the door lock with an OEM brand new lock set but with no effects.
What is going on here? Is it possible that the control module suppose to get reset from the panel upon turning the machine on, but it doesn't happen for some reason? I purchased an OEM brand new module, but have not installed it yet since this discovery. Is it possible that the issue is with the control panel, perhaps the power switch on it?
