darmentle
#1 Posted : Friday, July 8, 2022 6:37:26 AM(UTC)
darmentle
United States
hello my dryer first stopped working on high heat and it only worked low heat for about a week and now no heat. i checked the fuse, thermostat, one of the spade connectors on the heating element is flopping around can the that cause the issue . i tested continuity and it worked?
Edited by user Friday, July 8, 2022 6:39:59 AM(UTC)  | Reason: Not specified
