HI, It stopped working after about 4 years of service. The digital readouts in the front are dead and the compressor is not working. (warm wine...ugh). I did verify that it is getting power. Any ideas on what I should try next? Thanks Bill This is an answer to a post I submitted to Doityourself.com forum. Doesn't look good. I'm seeing a lot of discontinued replacement parts from Edgestar. This unit uses three boards.... power supply, control and display. There was a kit available with all three. Do you have any electronics knowledge ? You need to check for voltage on the power supply board. Don't see any fuses for protection. Edited by user Tuesday, July 5, 2022 7:29:14 AM(UTC)
| Reason: update
