justme0987
#1 Posted : Monday, June 27, 2022 5:14:35 PM(UTC)
justme0987
United States
I have LFFH21F7HWG upright freezer
I have an error message "Door Ajar"
The door is well closed and the light switch is working fine, turning the light on and off when pushed manually
The door Gasket is very good
The freezer works great the only problem is the beeping error message "Door Ajar"
If I replace the door switch would this fix the problem? Please let me know
