Our ice maker will not make ice if the ice bin/auger assembly is in place. If we remove the bin the ice maker will make enough ice to fill the entire ice maker with perfectly sized ice cubes and eventually fill up enough that it flows out the front or trips the paddle. This is new ice maker and the 2nd ice maker in the fridge since we purchased it, also replaced the inlet blower thinking that not enough cold air was getting in to satisfy the thermostat.
