I have a Thor 36 inch Pro-style 6 Burner Gas Range. It's setup to use propane. Both the oven and broiler no longer light. Both stopped working at the same time. Both igniters glow when they are turned on. If either one or the other had stopped lighting I would have figured it was the igniter, but since both stopped working at the same time I'm thinking it's something else. Also, I changed the oven igniter a couple months ago so it's unlikely that's the issue (but i guess still possible).
Anyone got any ideas? Thanks.
