I can start a wash cycle and it will run fine up until I get to the drain and spin cycle. At this point it stops and either gives a drain error code (if it hasn't drained - this is intermittent) or just stops as if waiting to get to then next part of the cycle (it usually drains). I've gotten into the service mode and there doesn't appear to be any error codes. Using the service mode I can run a spin cycle with a few clothes (but not a full load) and it drains and spins fine. It's almost as if it somehow senses that the load is too heavy. I'm at a bit of a loss on this one. Any help is appreciated. Thanks.
