lgmccoy1
#1 Posted : 17 years ago
lgmccoy1
I have a 2 year old Kenmore Ultra Wash Quiet Guard 3 dishwasher Model No.
665.16014402. Problems started when I noticed a loud noise during the wash cycle for a week. Next thing I know when I tried to use dishwasher another day the green led "Clean" light is flashing. I can't get the dishwasher to do anything no matter what I press. So I call the local service center, they tell me I need a new control panel. I spend a hundred bucks install it myself, it cures the flashing light.
So now I start a wash cycle to test it, dishwasher fills with water but then when wash cycle is suppose to start, I wait and wait, it does nothing. I do notice a humming coming from the motor like it is trying to start but still nothing, so I turn it off for fear of burning motor up. I tap on the motor thinking maybe it's hung up or something, still nothing. I'm a DiY'er but this time I decide to take it to the local service center since dishwasher is only 2 years old. By the way, called Sears to see what it would cost, they wanted to charge $65.00 just to look at it, my local service dealer doesn't charge to diagnose just labor to install the parts you buy from them, so I took it there.
I get a call in a few days, they tell me I need a new motor. Labor plus parts
would set me back another $145.00. I decide to find a motor myself and install it. So I refer to the ever dependable internet and happen along upon this site. After doing some searching in the forums I find out that my flashing clean light is actually telling me that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.
So I install the old control board to see if this could have been the problem.
At this point I'm wondering if the service tech I spoke with on the phone even knew this and maybe told me it needed replaced to make them some money. So I initiate the diagnostic cycle that I got from the schematics and what do you know, brought my supposedly dead board back to life. Now I'm wondering if the motor is even bad. According to my schematics the diagnostic cycle is suppose to last 16 minutes 15 seconds but it doesn't. At approximately 3:30 the dishwasher shuts off, no leds lit, nothing. I restarted the diagnostic cycle several times and it always turns off after 3:30. If I'm reading the schematics right, at about this time the motor is suppose to activate. I remove the motor, it turns freely. The water pump impeller seems to be turning freely.
At this point what else do I need to check? What setting do I set my digital multimeter to and how do I check my motor with it. My motor has a capacitor attached to it by the way. Also where is motor relay and how do I check it? Any help would be greatly appreciated?
MRMATT222
#2 Posted : 15 years ago
MRMATT222
Hi, I was wondering if you found any solution to your problem. I am having something similar
Matt
lgmccoy1
#3 Posted : 15 years ago
lgmccoy1
Probably was the motor but I refused to spend the money for a motor so I ended up buying a new dishwasher. I parted out the Kenmore on ******** and still have it stored in my attic, whats left of it.
MRMATT222
#4 Posted : 15 years ago
MRMATT222
OK, thanks, - think I'll risk the money and try a new motor
Matt
