Joined: 4/27/2022(UTC) Posts: 0  Location: Gig Harbor
I have a 2011 Maytag Centennial Model: MVWC6ESWW0, that won't agitate but spins just fine. I replaced the dog ears, inspected the teeth in the upper and lower agitator, and replaced the run capacitor. There are no belts underneath where the transmission and motor sit right under the drum. I spent quite a bit of time searching online through youtube but haven't found a solution short of dropping the transmission, at which point I wonder if it would be worth fixing. Thanks.
