Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
So, looking at other similar issues on these forums it appears this is a circuit board issue. I've tried to find the right part number, but I am not 100% sure of it. Basically, the dry heats, then at the end of the cycle the heat turns off and it just spins. I've pulled the lint bousing off, cleaned the sensors and the trap but that didn't help.
