Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hello Friends!
Just moved into furnished Condo & want to replace water filter in my 2006 Bosch B20CS50SNS/01 Refrigerator. The Owner's Manual suggests to disconnect water supply before replacing water filter, but I'm not able to pull out the monster refrigerator to disconnect the water supply. Can anyone that knows about this model let me know....can I just pull out the old water filter and replace with new water filter....or....is water going to squirt everywhere....when I try to replace it? Also...I read that I can just turn off water at the sink across the kitchen and that will do it....Will that work? Any help would be great....since I"m in a condo....can't turn off the water to the building!!!. Thanks for your help! Robin
