tookien
#1 Posted : Monday, April 11, 2022 1:15:42 PM(UTC)
tookien
Hello,
I have a maytag Mvwx655dw. Washer is about 4 years old.
It leaks a little water + oil during spinning.
No noise or anything out of the ordinary (like bearing/gear noise).
I can see the dirty water on the motor pulley underneath.
If it was just the oil, then I assume it would have all leaked out by now from the transmission.
But there is water oil mixture.
So my noob guess is a seal is letting through the water which then gets to the transmission gears and spills out with it.
The tub seal is the only thing I could really find as a replacement part to buy.
Could that be causing this problem or does this require a whole new transmission?
Thank you for the help
Edited by user Monday, April 11, 2022 1:16:33 PM(UTC)  | Reason: Not specified
