Joined: 4/10/2022(UTC) Posts: 0  Location: New York State
The spark module (for the top burners) is at the rear of the range on a metal bracket with the screws facing front. I don't see any way to access those screws from the rear. I can only see one of them. I found this, but it is NOT the correct spark module (different module & bracket design); https://www.repairclinic...1596/400570#relatedMediaEdited by user Sunday, April 10, 2022 5:26:06 AM(UTC)
| Reason: corrections
After taking a closer look, It appears that the module has two 'tabs' one on each side making removal somewhat easy. But All the pics of the replacement parts don't have both of the 'tabs'. Only one and a screw tab extending outward of the housing.
