Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I think the water from defrost cycle is not flowing into correct place and eventually blocks the 3 air vents in the front above ice maker compartment. Maybe the unit needs to be tilted back a bit?
