Guest
#1 Posted : Monday, April 4, 2022 12:38:34 PM(UTC)
Guest
Rank: Guest
United States
Hello,
I have a LG WM3570HWA, purchased on May 2016.
It's been leaking water from below the washing machine for sometime. I thought it was the "Tub-to-Pump Hose with Bellows" and replaced it but that did not fix the problem.
I ran again and then opened the back and noticed the water was filled in the top of the Air Chamber (https://www.appliancepartspros.com/lg-chamber-air-3504er3002a-ap4439206.html) and roughly half of the black tube that goes into the Air Chamber was wet.
The black tube seemed to be wet only till a white tape that was there in the middle of the tube.
Question:
- Is it possible for the tube or the air chamber to cause a leak?
- What is the correct name and part for the black tube and what goes at the other end. In other words how hard is it for a regular person to fix?
Thanks for all the help,
Roy
