Guest
#1 Posted : Thursday, March 31, 2022 2:56:03 PM(UTC)
Guest
Rank: Guest
Groups:
United States
The drum turns fine and it lights and heats if I keep holding down the start button, but the moment I release the button it stops. Replaced the main control board and symptom remains the same.
Thermistor reads 19.1 ohms. Thermal fuse has continuity. switched the two motor relay wires with no change. 48 VDC across the two pink/black wires when I press the start button and they stay that way when I release it.
Is 19 ohms OK on the thermistor? Is there anything you can suggest I measure?
