Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have a Kenmore washing machine #110.92284100 I replaced the transmission and brake. The tub spins while draining after first wash then on the rinse cycle it works fine, it drains first then spins. What can I do to fix it, or do I need to replace the timer. It does the same on Normal Wash and Heavy Duty wash cycles.
