Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
The machine works fine on the cycle, fills water and agitates. When it gets to rinse it drains and spins, but then it stops. It does not fill water again and do the rinse part of the cycle. This happens with all cycles. The switch timer(3953146) corresponds with the machine model as n I understand. Thanks in advance for any idea or suggestion.
