110.22882101 fills then nothing. Timer not making sound. Manually advancing timer does nothing. Machine used to wash with lid open so do not think it is lid switch. Tried different timer still nothing. Ideas? Thanks.
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
I'd check the wiring to the speed switch and to the motor. It might be a bad motor or motor start switch (part of the motor these days). Is the washer over 15 years old? Are you sure you have power to the timer?
