Hi folks, My washer wt5070cw is leaking water after during what I believe is the detergent cycle. The water fills up correctly and it spins as expected. During the second part of the washing, I can see the water filling the bleach dispenser and the water leaking from a hole/vent at the top back of the washer. Picture here: Leak imageI have recently replaced the inlet valves which were also leaking. Any idea how to fix this? Thanks [img=https://photos.app.goo.gl/h7AAgq5FRJgdsEYJ7]Leak[/img] Edited by user Tuesday, March 1, 2022 7:06:54 AM(UTC)
| Reason: Not specified
