Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
My dishwashers touch doesn't work I've replaced both control boards for it. There are not lights or sounds when I push the buttons but what I do see is that the wire harness from the control to the touch is shorted to the body of the door not the actual unit. Can that cause this issue or is that something else.
