Joined: 2/16/2022(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: California
I have a Samsung NE63A6511SB/AA and am trying to completely disable the wifi on the oven, so it will stop transmitting. It's causing interference and either way, just don't need it and want it to stop transmitting.
I know there's a few buttons I can press to turn it "off", which doesn't actually stop it from constantly transmitting a wifi signal. The only way, from what I understand, is to physically cut power to the wifi module.
Does anyone know where the wifi module is located on the oven? Or what to unplug to actually disable it?
I combed through the user manual, and also the physical paper electrical schematic located behind the back panel of the oven... none mention anything about the wifi transmitter, nor it's location in the oven.
I opened up the back panel, and could see the wires and sensors going into the actual oven, and to the range, but did not see anything that could be a wifi transmitter, or anything on the circuit board which hinted at a wifi transmitter.
Have no idea where they could have put it, or where it's getting power from... I started to take apart the side panels, but it seemed like a much more intensive job which would require disassembling a good part of the oven and range.
Anyone have any advice they could offer?
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Why is this not answered? I need to know the same sort of thing about a new washing machine.
Rank: Guest
Just got help with this: Steps: Hold the Clock Button for 3 seconds Press 7 for WIFI settings Press 2 for OFF / 1 for ON Press START/SET to save.
Joined: 5/11/2022(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: California
Originally Posted by: BaristaSpot ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have a Samsung NE63A6511SB/AA and am trying to completely disable the wifi on the oven, so it will stop transmitting. It's causing interference and either way, just don't need it and want it to stop transmitting.
Anyone have any advice they could offer? Navigate:Settings > Settings icon Connections Wi-Fi. Ensure that the Wi-Fi switch (upper-right) is turned on Switch on. Tap the gear next to Wi-Fi network you wish to remove. click to Forget.
Rank: Guest
Rank: Guest
You hold the light button for three seconds in my Samsung oven for settings. Not the clock button. But the rest is accurate.
