Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have an older GE GLWN2800D0WS that now doesn't agitate or spin. I tried themotor reset method and it worked, than stopped...tried it again and it doesn't work. I have put a magnet on the lid switch and it worked for one time, but then didn't. So none of it adds up to me.
The belt is good, very tight on the motor. I can hand turn the agitator and the tub turns too, I can vusually see the belt move. I was able to try a motor from a different machine and it did not fix the issue. I have tried a timer from the same machine and that did not solve the issue either.
I have continuity between the positive terminal of the power cord and the orange wire on the motor so it doesn't sound like a lid switch. I have continuity between the two end terminals on the pressure switch, and when I blow in the tube I lose continuity, the one end and the middle gets continuity when I blow in the tube.
Help, what am I missing here?
