GWJ
#1 Posted : Wednesday, February 9, 2022 10:09:58 AM(UTC)
GWJ
United States
I have a Samsung WF419aaw that was getting an LO Code - door lock code. The door would fail the lock test. I replaced the door lock and it still gave the code. I tested voltage at the PCB and was only getting 90v. Replaced the PCB and it worked and I ran 4 loads without issues.
This morning I ran another load and got the LO Code again.
What else is there to replace? The wiring harness is perfect.
